sha2
RFSoC example program baremetal source code
Hello
Iam going through the following guide for adc/dac evaluation
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/57606309/ZCU111+RFSoC+RF+Data+Converter+Evaluation+Tool+Getting+Started+Guide
In the Rfdc Example program there is the  # rfdc-data-write-example that we can run from the terminal
Where can we find its source code  ?
I check on xilinx github on the below , there is the # rfdc-read-write source code and the# rfdc-selftestsource code but not source code for # rfdc-data-write-example
https://github.com/Xilinx/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/rfdc/examples
Thank you very much
Shalom
pthakare
Hi @sha2
# rfdc-read-write and # rfdc-selftest  are part of RFDC softwae driver code and hence you can find the source code in xilinx github or in SDK
installation under embeededsw folder.
# rfdc-data-write-example , is not the part of RFDC Software Driver code.
sha2
Hi thanks for the answer
but xilinx dont provide the source code ?
Shalom
klumsde
Is this one of the applications that is part of the ZCU111 RF Data Converter TRD?
It loads a vector into the BRAM and transmits it from the DAC?
If you re-create the petalinux project you can likely see the source for this one in the recipes
Somewhere like
project-spec/meta-user/recipes-apps
sha2
OK
Thank you very much
Shalom
