arashr
RFSoc ADCs' Clock Phase Adjustment
I'm using ZCU111 and I need to adjust when ADCs of two tiles sample data. I have read the documentation [269] but my question still exists. How does MTS achieve synchronization, does it shift the LMX2594's clock phase?  If not, is it possible to adjust the clock phase of a tile?
In other words, I want ADCs of one tile operate at a clock phase of 20 degrees offset relative to another tile.
Thank you in advance for any advice.
pthakare
Hi @arashr
To understand the how MTS achieve syncronization , you need to first figure out what are the possible source of latency mismatch across the tiles:
Please refer to the blog below by our expert to understand the MTS procedure
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Getting-in-Synch-with-RF-Data-Converters/ba-p/1071111
pthakare
Hi @arashr
