Re: Issue inferring XPM True Dual Port RAM
From my understanding that is just to indicate that I would like to use byte enables and I do want to use them...
I'm just writing words which are multiples of bytes, so that should be kind of OK...
I don't think that this is all so very strange what I am doing. We are also using FIFO's in our design which convert between 32 and 512 bits using XPM macro's...
Hi @dannyjacobs
This is aspect ratio limitation when byte writes enables are used
Reference  https://www.xilinx.com/support/documentation/ip_documentation/blk_mem_gen/v8_4/pg058-blk-mem-gen.pdf   -> page 51
I have confirmed this with below test cases.
I have checked the synthesis at my end for shared parameter setting in the forum post and encountered  with same synthesis error.
I then disabled the byte writes feature and I am able to synthesis without any warning .
When using block memory generator , byte write enable and write width port A is 512 , you can only have write width for port B of 128, 256, 512, 1024 and 2048 which is within the range of aspect ratio 4
I hope this helps.
Reply if you have any queries, give kudos and accept as solution
Hi @dannyjacobs
I hope this helps.
Hi pthakare,
Thank you for your response, I was kind of affraid of this...
Does this mean that I can't use my byte enables but just need to write my whole 512 bits word at once and all data that was previously stored is at some point in my 512 bits word is going to be overwritten when I do a write?
Cheers,
Danny
Hi @dannyjacobs
Yes , the alternative is to  read -modify (the byte you want) and then write .
OK, I'll change my implementation.
Thanks for your help!
Cheers,
Danny
