Reading CNTVALUEOUT from IDELAYE3
If I'm using IDELAYE3 primitive in the VARIABLE mode, can I still read the final tap value from CNTVALUEOUT port by setting EN_VTC pin low. Or does the CNTVALUEOUT port only work in VAR_LOAD mode?
Re: Reading CNTVALUEOUT from IDELAYE3
Hi @legoman
Yes You can read the final value from CNTVALUEOUT[8:0]  on waiting for minimum of 5 clock cycles after increment of decrement the  delay line.
As you know in Variable mode the CE and INC pins are used to increment and decrement the delay line.  You need to follow below sequence from UG 571 [https://www.xilinx.com/support/documentation/user_guides/ug571-ultrascale-selectio.pdf]
Here you can read CNTVALUEOUT port after step 4 to ensure that increment/ decrement is happening as expected.
Please reply if you have any query, Give Kudo as Accepted as solution if you get the resolution of your queries.
Hi @legoman
