adam_mira
Reading the FPGA temperature simply
I am using Vivado 2020.2 and working on Ultrascale based FPGA.
I want to pass on the FPGA's temperature using its built-in SYSMONE1 primitive.
I don't want to hassle with tons of settings I don't need like clocking, DRP, AXI, I2C, and so on like presented in the System management wizard IP.
All I need is an output port containing the most recent temperature read, which automatically updates without any request or command.
The sampling speed and refresh rate are not very important.
Any idea about the simplest way to achieve my goal?
Thank you!
tenzinc
DRP is needed at the basic level to read SYSMON registers including the temperature. You could let SYSMON run under the hood in default mode and read the temperature via JTAG-DRP as Vivado HW manager does. You can run tcl commands like get_hw_sysmon_reg to read temperature like so:
set opTemp [get_property TEMPERATURE [lindex [get_hw_sysmons] 0]
Other than that you'll need to use one of the interfaces you listed.
T
Get started FAST with our UltraFAST design methodoly guides and don't forget to visit our Xilinx Design Hubs for additional resources and reference.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
