shaikon
Voyager
Voyager
Reading the part number from silicon
Do Ultrascale FPGAs have a hardcoded register that allows reading the full part number (including speed grade) ?
@shaikon
Page 134 of UG570(v1.10) says that each UltraScale device has a unique device identifier (DNA) that can be read using the DNA_PORTE2 primitive.  See also the following AR that says a Xilinx barcode device is needed to interpret the DNA identifier.
https://www.xilinx.com/support/answers/71342.html
Information about Xilinx barcodes is given at the following site.
https://www.xilinx.com/support/answers/67513.html
Mark
@shaikon
Mark
shaikon
Voyager
Voyager
What I wanted to do is decode the hardcoded number in runtime and make my logic run differently based on the speedgrade.
If the DNA requires an external tool - this doesn't seem possible.
It seems unusual to postpone decisions that are based on speed-grade until the bitstream is loaded into the FPGA.  -since, changes in speed-grade typically cause changes in the bitstream.
That is, before running synthesis/implementation you must tell Vivado about the speed-grade of your part using a Tcl command something like the following.
set_property part xc7k160tfbg484-2 [current_project]
Since you must manually tell Vivado about the device speed-grade, it is reasonable that we should manually need to tell our HDL about the device speed-grade.  Unfortunately, I have found no way to query the “part” property of current_project and pass it to HDL.
In VHDL, we usually specify things like speed-grade using a global-constant in the VHDL package file for the project.  Then, VHDL components in the project use the global-constant in if-generate blocks (see pg193, UG901, v2019.1) to only synthesis HDL that is appropriate for the selected speed-grade.
