xinyiz
SYSMONE4: assign auxilary analog input to two different banks
I have a requirement that we want to use auxilary analog inputs of system monitor on different IO banks on Zynq Ultrascale+.  When I look at UG580, it says the SYSMONE4 allows up to 2 banks to support the auxilary analog input connections, so it should be possible. But when I use vivado to configure the system management wizard, it only allows me to select one IO bank as the attached picture shows. Is there any way for me to put the IOs on different banks?
If these are the pins I need:
IO_L3N_AD9N_26
IO_L3P_AD9P_26
IO_L2N_AD10N_26
IO_L2P_AD10P_26
IO_L12N_AD8N_24
IO_L12P_AD8P_24
IO_L11N_AD9N_24
IO_L11P_AD9P_24
IO_L10N_AD10N_24
IO_L10P_AD10P_24
IO_L9N_AD11N_24
IO_L9P_AD11P_24
IO_L3P_AD13P_24
IO_L2P_AD14P_24
Do I need to use 2 system management wizard and assign the input pins to different banks?
Thanks!
pthakare
HI @xinyiz
Yes , System Management Wizard GUI doesn’t support this option yet. The workaround is to modify the XDC file to map the second bank pins to the design.
