sm2
Thermal Resistance XQKU5P-1SFRB784
Good afternoon.
I would like to request the thermal resistance values for XQKU5P-1SFRB784.
* Theta-JC (junction-to package top case)
* Theta-JB (junction-to-board)
* Junction-to-package bottom case, if applicable.
Thank you in advance.
tenzinc
These should be documented in UG575
https://www.xilinx.com/support/documentation/user_guides/ug575-ultrascale-pkg-pinout.pdf
We also supply thermal models as well if you are intended on performing thermal simulations and would like a prepackaged package thermal model.
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/device-models/package-thermal-models/utrascale-plus-fpgas.html
TC
Get started FAST with our UltraFAST design methodoly guides and don't forget to visit our Xilinx Design Hubs for additional resources and reference.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
tenzinc
TC
