quincyq2003
Ultrascale SSI issue
Hello
The ultrascale is multi-die, how many between SLR and SLR connector wire?
FPGA device: xcvu440 2982
sandrao
Community Manager
Community Manager
just did a quick test myself and it looks like the property is called NUM_TOP_SLLS, try the command
get_property NUM_TOP_SLLS [get_slrs SLR0]
I'll file a change request against the UG.
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
gnarahar
Not sure what you mean by "how many between SLR and SLR connector wire?"
Do you mean which Banks / how many are located in each SLR region? If yes, check Page#104 of UG575 http://www.xilinx.com/support/documentation/user_guides/ug575-ultrascale-pkg-pinout.pdf
If that isn't what you looking for, may be you can rephrase your query.
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
quincyq2003
Hello @gnarahar
Ultrascale FPGA device is 3D IC(xcvu440 are three of die to combin)
In this picture(7-series example), how many between SLR and SLR connector wire?
https://www.xilinx.com/products/silicon-devices/3dic.html
sandrao
Community Manager
Community Manager
The connections between SLRs are called SLL - Super Long Lines. From UG574 : https://www.xilinx.com/support/documentation/user_guides/ug574-ultrascale-clb.pdf
The total number of available interconnect flip-flops in a device depends on the number of clock regions in a row and the number of SLRs. The KU115, for example, has six clock regions per row and consists of two SLRs, so there are 69,120 interconnect flip-flops available to support the 17,280 SLL connections across the SLR boundary. The number of SLLs for a given SLR can be reported using the Tcl command get_property NUM_SLLS [get_slrs SLR0].
Sandy
quincyq2003
Hello @sandrao
I want to enter Tcl command get_property NUM_SLLS [get_slrs SLR0], but report error message:
How do i can resolve this issue?
get_property NUM_SLLS [get_slrs SLR1]
ERROR: [Common 17-54] The object 'slr' does not have a property 'NUM_SLLS'.
sandrao
Community Manager
Community Manager
Sandy
quincyq2003
Hello @sandrao
This tcl command is correct.
Thinks for your help.
