webstar_2002
Vivado only placing in one SLR?
I am migrating a desing from Kintex to Kintex Ultrascale because it needs more logic resources than available. I am migrating from Kintex 480 to Kintex Ultrascale 085.
The migration of the project is done now, it is also possible to synthesize and do implementation. Problem is, Vivado is only using one SLR (SLR0). Why is that so? I thought the distribution of the logic including inter-SLR communication is done automatically? Otherwise the big 3D ICs are actually not as useful as the marketing says...
BR, Markus
vemulad
Hi @webstar_2002
Do you have congestion issue due to this? The placer might be packing the design in to one SLR inorder to be able to meet timing constraints.
If you would like to spread the logic you can use pblocks or directives like spreadlogic_high
Deepika.
vemulad
Hi @webstar_2002
Deepika.
webstar_2002
Hi Deepika,
it seems so, at least with pblocks it works now. Still I found it quite curious that the placer actually tried to place it all in that tiny space thinking that it would help...
Thanks for your answer!
