What is the maximum frequency we can have for our design on xillinx fpga's ?
I have a requirement of 900Mhz clock is this possible on fpga's ? My design currently suts on ZCU 102
Anjaneyulu
@anjaneyulu.challa9,
Check the following forum discussion:
https://forums.xilinx.com/t5/Welcome-Join/Maximum-frequency-of-Device/td-p/697099
Please create a design and see the maximum operating frequency of the design from timing analysis.
--Syed
The data sheet indicates that the Fmax for a global clock tree or DSP slice is 891MHz for a -3 part running at 0.9V.  For a ZCU-102, I think it is a -2 part at 0.85V.  This has an Fmax of 775MHz..  If your clock requirement is for anything in the FPGA fabric, and not just a gigabit transceiver, you should re-think the design.
Sorry I did'nt get that
