ZCU102 Software Reset Hanging
I'm wondering if anyone else is seeing this behavior.  I am running the pre-built 2016.4 ES2 Linux images on a ZCU102 ES2 board, and any shutdown method I have tried hangs.  The simplest case is to issue a reset in uboot.
U-Boot 2016.07 (Dec 16 2016 - 03:23:39 -0700) Xilinx ZynqMP ZCU102
I2C:   ready
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        xczu9eg
MMC:   sdhci@ff170000: 0
SF: Detected N25Q512A with page size 512 Bytes, erase size 128 KiB, total 128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   ZYNQ GEM: ff0e0000, phyaddr 12, interface rgmii-id
eth0: ethernet@ff0e0000
ZynqMP> reset
resetting ...
PMUFW: PmSystemShutdown: (1, 0)
When I try this, it hangs there indefinitely.
OK, I found this answer record:
https://www.xilinx.com/support/answers/68514.html
While it doesn't provide a workaround for u-boot, it does at least identify the cause.
