fanwei
ZCU111 DAC and ADC loop testing with XM500
 hi,
  I have zcu111 board , i want to run a loop testing ,using DAC: send data(500Mhz),and mixer with 2Ghz,out .
  Using XM500, dac analong data  send to ADC, ADC sample rate at 4Ghz, and mixer with 2Ghz, and check data is right
  now,i have a problem:  the circuit determines ADC input must using DC-coupling,but  the the adc vcom voltage how to connect?
klumsde
can you just use a Balun on the xm500?
This doesn't need the link coupling to be DC.
klumsde
fanwei
thank you for reply. it seem to a good idea,
where i can find Balun  reference circuit  to  design my system?
fanwei
As far as I know,Balun can signal-end to diff or diff to signal-end
DAC output is diff signal ,ADC input need diff signal ,how using Balun in this design?
klumsde
There are Balun channels on the card. Take a look at the ZCU111 User Guide. There is an appendix that shows you each channel
fanwei
ok, i find it
