jack1977
Zynqmp power consumption
Hello. I have custom board with XAZU3EG-1SFVC784I device.
I find what in power on reset mode (POR_B signal tied to GND) chip consumes ~1-2W.
maybe someone had a similar problem?
klumsde
Is that total or just on a particular rail.
There is always going to static current.
What is the die temperature you read on the sysmon? Can you force the XPE sheet to have this Tj and see what the expected power consumption is?
