behnam_2705new
high-speed serial I/O
I have a serial Async I/O( rate of data is 622.08 Mbit/s).  I am familiar with HSSIO Ip core. but the input rate is bounded from 800 to 1200 Mbit/s.
My data rate is less than this boundary. what should I do to capture my data correctly? (I have KCU105)
borisq
hi @behnam_2705new
below is an application on KCU105 with a FMC loopback card.
https://www.xilinx.com/support/documentation/application_notes/xapp1315-lvds-source-synch-serdes-clock-multiplication.pdf
This is for synchronising clocking.
For async clocking design, you need to use oversampling.
Below is an application targeting 7 series for your reference.
https://www.xilinx.com/support/documentation/application_notes/xapp523-lvds-4x-asynchronous-oversampling.pdf
Boris
borisq
hi @behnam_2705new
Boris
behnam_2705new
Do you mean that I can not use I/O in native mode? by instancing primitive cell, like RX_BITSLICE, for this scenario?
drjohnsmith
sound slow,  are you using a 'normal' IOB pin, in serial mode, or one of the GTH serdes blocks,
behnam_2705new
I am not using GTH block, I want to capture a data from I/O. first of all, HSSIO absorbed my attention, but after reading PG188 and XAPP1274, I realize that I cannot use this IP for my scenario, my data rate is less than the boundary that HSSIO's PLL wants. I want to use I/O from HR, HP or HD banks.
drjohnsmith
I think you need XAPP1064 and XAPP585
behnam_2705new
I should have mentioned that I prefer to use native mode and my data is in ASYNC mode, Clock does not come into the FPGA with data. I have LVDS data input with a rate lower than 800 Mhz. (like STM-1 155 Mhz and STM-4 622 Mhz) .
two application note that is mentioned by you is about source synchronous and using SERDES primitives. ( as you know SERDES primitive is a part of component mode I/O), Xilinx shows in https://www.xilinx.com/video/fpga/using-io-in-native-mode-vs-component-mode.html that using I/O in native mode is better than the component mode because of their architecture in the Ultrascale boards.
drjohnsmith
@behnam_2705new
thanks, when I get to amachine I can give kud on, I will.
its an interesting technique, and new to me, so I'm keeping an eye on it.
     is the speed limit the IO, or the MMCM ?
          if tis the MMCM, can you run it at twice the clock rate , and divide by two on the clock outputs of the MMCM ?
behnam_2705new
If I understood correctly this limitation is because of the PLL input clock. In the HSSIO Ip core PLL clock is dedicated and we cannot use the MMCM(MMCM exist in a native mode I/O block ) because of some issue that Xilinx wants to do for high-rate signals(like dedicate clock routing).
drjohnsmith
Do u have link to this core please .
Interesting .
behnam_2705new
Hi @drjohnsmith, Thanks for your Kudos.
This is a documentation for  HSSIO Ip core
https://www.xilinx.com/support/documentation/ip_documentation/high_speed_selectio_wiz/v3_4/pg188-high-speed-selectio-wiz.pdf
Xapp1330 is documentation that describes Asynchronous Data Capture Using the High-Speed SelectIO Wizard
https://www.xilinx.com/support/documentation/application_notes/xapp1330-async-data-capture-hssio.pdf
Xapp1274 is documentation that describes Native High-Speed I/O Interfaces
https://www.xilinx.com/support/documentation/application_notes/xapp1274-native-high-speed-io-interfaces.pdf
excuse me @borisq  don't you have an idea to capture data below HSSIO rate boundary by using native high speed I/O interface?
drjohnsmith
Thank you
Im always amazed, been in the business 40 years, started FPGA's with the Xilinx 3000 series, still finidng new things that they have in them !
Time for a long read,
