how does OSERDESE3 work for DDR/ SDR?
I want to use OSERDESE3 on a Zynq Ultrascale+. UG974 page 498 states:
Attribute   Type  Allowed Values   Default   Description
ODDR_MODE STRING "FALSE","TRUE" "FALSE" Internal property for Vivado primitive mapping. Do not modify.
So how does one specify whether is DDR or SDR?
@pthakare
That makes me think... is DDR/SDR respect to the input? to me, the input is 8 bits per input clock period, i.e. SDR.
I've tried different cases and noticed output is always DDR
pthakare
Hi @archangel-lightworks
If i presume correctly you have Parallel data (8 bits)  synchronous to clock  (this clock is CLK_DIV here)
what is DATA_WIDTH attribute set to ?
The OSERDESE3 can serialize an outgoing signal by a 2 or 4 in SDR mode, or by a 4 or 8 in DDR mode. When used with SDR clocking, the DATA_WIDTH attribute is to be set to twice the desired width and data to be transmitted should be applied to two pins at a time
x8 in SDR mode is not supported.  follow below table for proper connection and DATA_WIDTH attribute setting
additionlly please refer to OSERDES section of UG571 -. page 165 onward on detailing of OSERDESE3
https://www.xilinx.com/support/documentation/user_guides/ug571-ultrascale-selectio.pdf
