Participant cb_cross
how to interpret result of mrd of PS SYSMON registers
Specifically, I have a ZCU104 board.
More generically, I am looking for information regarding the ZU+ MPSoC PS SYSMON.
I have searched the User Guides that make sense to me to look in.  I have googled.  I have searched these forums.  I cannot find the information necessary to decode the result of:
xsct% connect
xsct% targets -set -filter {name =~ "Cortex-A53 #0"}
xsct% rst -processor
xsct% mrd 0xffa50818
That is the address for the measurement of VCC_PSAUX, which should be 1.8V
The result was:
FFA50818:   00009940
In UG1087, I see that:
Bits [15:6] = 10-bit ADC measurement.
Bits [5:0] LSBs.
Which leaves the ADC measurement at 0x265. or 10 0110 0101 binary.
I don't see how that number comes out anything close to 1.8
As I've said, I can't find any documentation which says how to translate these measurements.
Any help will be much appreciated.
Re: how to interpret result of mrd of PS SYSMON registers
For a voltage sensor, generally the transfer function is
V = ((ADC Code) / 2^nbits) * 3V
The sensor output is scaled by a 1/3 so you've to scale it back up again to go from raw codes to volts
0x256 is 598 in decimal
Divide by 2^10 is 0.583984375
x3 then gives about 1.75V
This detail can be found in ug580
Hope it helps
Hope it helps
klumsde,
Thank you for the answer.
I never would have figured it out by the description in UG580. The ADC Transfer Function formula is never actually given.
The user guide details the power supply sensor on page 41
Equation 2-13 shows this calculation
