fanwei
the relationship between PL_CLK and m_axi_clk when in ZCU111 Multi RF-ADCs tiles synchronization ?
    There is a question for me  when for Multi RF-ADCS tiles synchronization.
    in pg269 (v2_4 ) page176,when adc and dac working  on different clock rates,the PL_CLK must be common multiple or sub-multiple of the          RF-ADC andRF-DAC AXI4-Stream clocks,show below:
   but when only using multi-ADCs Tile, the PL_CLK is also be common mulitple or sub-multiple RF-ADC AXI4-Streams clk?
pthakare
Hi @fanwei
With these frequency values , PL SYSREF frequency is common sub-multiple of all the clocks in the system.
But PL_CLK is not  common multiple or sub-multiple of the RF-ADC AXI4-Stream clock.
I will discuss internally if you this works for MTS or having the PL_CLK common multiple or sub -multiple of the RF_ADC Stream clock is stringent requirement and that need to followed strictly.
Reply if you have any queries, give kudos and accept as solution
fanwei
in my project,my adcs  working on sample rate 3.328Gsps. real-->I/Q   2xDecimation with NCO. So need  axi-stream clk is 208M.
i will using LMK04208(VCO freq :3072Mhz) generate 8M analog SYSREF and PL_SYSREF, but I can not config clk divider in LMK04208 to generate PL_CLK that mulitple or sub-multiple of the axi-stream clk,
i will try to generate 96M  PL_CLK   and  use a mmcm in fpga  to generate 208M  to axi-stream clk
pthakare
Hi @fanwei
fanwei
thank you  @pthakare  .
   So in my project , the LMK04208 can not generate the PL_CLK that is common multiple or sub-multiple of the RF-ADC AXI4-Stream clk.
   There is no guarantee that Multi RF-ADCs tiles synchronization.
   In another way,when  ADCS or DACS   sampling frequency is set strangely ,but LMK04208  can not generate the correct  sysref and PL_CLK frequency, it will fail when synchronization is         performed,
  Is there a solution here for applications with   setting strangely frequency?
fanwei
hi @pthakare
   i  have configured the LMK04208 PLL2  paramenter to  modify interal VCO  freq,and generated the PLL_CLK and analog SYSREF PL_SYSREF that i wanted,
    and these freq are sub -multiple of the RF_ADC sample clks/ axi-stream clk
