xapp524 equivalent for ultrascale
Is there an equivalent to xapp524 for the ultrascale architecture?
I have been trying to convert xapp524 design to use it in a Zynq UltraScale+ device (Ultra96 board), but realized that usage of most of the primitives has changed substantially.
Just wondering if there is already another reference design that i can use, before i dive into all the details.
Thanks in advance!
pthakare
Hi @navoda.perera.abb
There is no ready application note alternative to xapp524.
Designing using component mode application note will help in migration
https://www.xilinx.com/support/documentation/application_notes/xapp1324-design-selectio-component-primitives.pdf
Reply if you have any queries, give kudos and accept as solution
pthakare
