icstars
zynq ps ip recustomization strange behavior
Hello everyone!
I am working with project for zynq 7010
I need to set pl clock fequency to 100m
If I don't edit ps ip everything works fine
but when I change default clocking parameters, I get an error like this:Снимок экрана от 2020-12-21 15-06-01.png
-2 : -1 limitation for every clocking parameter looks strange Снимок экрана от 2020-12-21 15-11-21.png
Has anyone experienced something similar?
Please, tell me how to fix it
vanmierlo
Mentor
Mentor
You're probably using linux and have it configured for a language that does not use the dot as the decimal point. Go to language settings, possibly accept installing some extra parts, and change to use the dot as your decimal point. It might be better to completely change to English.
After that reboot and try Vivado again.
vanmierlo
Mentor
Mentor
icstars
Thank you!
I have changed regional formats from Russia to UK and zynq ip works fine now
