akhtar2510
12G-SDI example design
Hello
I want to receive data from 12G video chip and then process it.
I want to have any example design for UHD-SDI IPCore  but xilinx has not it !!!!
I use Virtex ultrascale evaluation board, VUC108.
please help me
florentw
Hi @akhtar2510
The best way to start is always to start with the example design with the corresponding HW. I recommedn you to contact your FAE to see if he has a board you can borrow.
Then looking at this:
https://forums.xilinx.com/t5/Serial-Transceivers/12Gbps-Data-recieve-has-error/m-p/980248#M4491
It might that the rate is not properly detected. If you have only one clock you need to make sure the core is not looking at the fractional rates.
Florent
florentw
Hi @akhtar2510 ,
What about the xapp1248 I mentioned in the previous thread (https://forums.xilinx.com/t5/Video/SDI-Dta-recieve-problem/m-p/979841#M25603)? This is an example with 12G.
There is no example for GTY but this example should be a good start...
Florent
akhtar2510
Dear
I dont use TB-FMCH-12GSDI Board. I create a test board and dont use sysnc separator and video clock generator. are they important ?
I have one SDI12G Equalizer and one SDI12G Driver and one 148.5MHz Oscillator and one 27 MHz Oscillator.
please help me
florentw
Hi @akhtar2510
Florent
akhtar2510
Dear
I use Example file. It is OK , I send 12Gbps (4K) video to FPGA and it's work very good, FPGA show Video Data and EAV  , SAV and etc. in additional FPGA Make 4K Video and i receive it very well.
Now i want to route Input to Output. I route rx_ds1 to rx_ds8 and rx_ln_ds1 (Line number) to tx port, but i cant receive video.
 please help me
joe306
Hello, what type of transceivers did you use: GTH or GTY?
Thank you
