02-20-2021 10:04 AM
Hi.
Is there any working example in VHDL for adv7123 IC interfacing with any xilinx FPGA.
If it's there kindly suggest some good links.
Thank you
02-21-2021 10:45 PM
I do not see any reference design with ADV7123 interface. But the design can be realized with a video processing block/test pattern generator connected to AXI-stream to video out IP with VTC. The output from AXI-stream to Video out along with Hsync & Vsync from VTC will be connected to physical ports of ADV7123.
With Regards,
HPB
02-21-2021 10:48 PM
Okay thank you. Is there any starter reference for what you said?
02-21-2021 11:36 PM
Below tutorial is the good point to start.
With Regards,
HPB
03-22-2021 05:01 AM
Hello @mubasheerahmed_12 ,
Have you gone through the design addressed in Video Series 19 and Video Series 20. If not, please go through these designs, Because these designs showcase, using on board HDMI on ZC702 fpga with ADV7511. It would be helpful for you as a reference to you to work with ADV7123. You can follow the similar method to work on your use case.
With Regards,
Ashok.
