sharknado
ALSA Codec Volume Control with distinct Xilinx PL Sound Card (Audio Formatter -> I2S cores) and Codec
Greetings Xilinx users and mods,
I have been tasked with developing sound functionality (Playback only!) for an embedded Linux device. The three blocks at play in this audio path are:
1) Xilinx audio formatter core
2) Xilinx I2S transmitter core
3) TI PCM1681 DAC
I currently have a functional Xilinx PL Sound Card and can play .wav files using ALSA utils' aplay command. Now I would like to provide high-level, user-space volume control via ALSA tapping into the DAC digital attenuation control. The complexity lies in the fpga "middle-man" components, which provide the means to transmit audio but not - AFAIK - configure the actual codec being streamed to!
What I have working:
  • streaming of .wav files through the Xilinx cores and into the PCM1681
  • volume control via direct I2C register writes. This is an undesirable interface for the user-space application.
Attempted solutions:
Replace Dummy-DAC DAI component of Xilinx PL Card
The Xilinx card bails here, so we are without sound card. Maybe I'm using the wrong names in the COMP_CODEC macro?
ALSA simple-audio-card device tree shenanigans
I thought producing a simple card with a dummy node might give me volume control, but I can't get such a card to come up.
Are either of the approaches I listed above valid? If not, is there any way to simply give ALSA control of the codec volume? Any help is much appreciated!
melofelossa
Hello!
I suggest you to not use the ASoC simple card soundcard driver. I struggled alot with it and at the end I still couldn't make it work with the Xilinx IP cores and drivers (Audio_Formatter, I2S Rx/Tx).
I contacted Kuninori Morimoto, the author of simple-card.c, and Alexandre Belloni from Bootlin. They gave me suggestions on how I could make it work but I still wasn't able to make it work.
At the moment it seems like the Xilinx drivers are incompatible with simple-card. But thats just a tought. You could take a look at the sourcecode to tell if they should be able to work together.
I conntacted the Xilinx support and they suggested me to use the Xilinx PL Soundcard driver. After that the support answered to my forum post to make the information public:
Solved: Re: Is the ASoC Simple-Card driver compatible with... - Community Forums (xilinx.com)
However, the Xilinx Soundcard is not as good as the Simple-Card driver because you have to be capable of linux device driver development. Also this is a much more time consuming task in comparison to just write a device tree node.
I found a guy who wrote a working Xilinx PL soundcard. Here is the link to his projekt:
Linux device driver for Zedboard audio (2/2) | by Yuhei Horibe | Medium
Here is the link to his soundcard .c file
zedboard_audio.c · GitHub
Note that he didn't use the 18,xx MHz dyamic MCLK which you SHOULD use. He decided to use a fixed MCLK with another fequency. Because of this he faced some problems which he mentioned at the end of his post.
Hope this helps!
sharknado
Thanks for the reply! I am checking out that resource now.
That post of yours is helpful for noting that the Xilinx PL and simple-audio cards are incompatible. That confirms what I have come to suspect. In light of that, the two approaches which I outlined in the original post may still be plausible solutions. Hopefully there is a way to replace that dummy codec component in the driver with the actual codec i2c component; it would be disappointing if the Xilinx PL soundcard cannot directly adjust controls, and that is the only way I see to do it. Maybe I just have the wrong names for my codec, but that is what appears in it's driver.
Thanks again for the response!
