hawthorn_3
AXI Stream Video encoding
Hey guys,
I am a little confused about the TDATA pixel mapping when trasmitting video data over AXI4-Stream interface. Below are two chunks of two different documents, where the descriptions are kinda opposite to one another:
The first one is more recent and states that the active data bits should be MSB aligned.
According to the second document the data should be LSB aligned.
Which configuration should be considered correct?
Rosi
florentw
Hi @hawthorn_3
The Xilinx video IPs are following the UG934. Please consider it as the most up to date.
Florent
florentw
HI @hawthorn_3
Updated: I have aksed the section "Video IP: AXI Feature Adoption" to be removed from UG1037. This should just point to UG934 which is kept up to date
Florent
