AXI VDMA timing violation issue
    In one of my project , i am using AXI VDMA to process the video frames. I have connected Read/Write Channel Clocks of the VDMA  to 200 MHz.So the Read/Write operation is based on 200MHz only. Even though i am getting timing violation inside the AXI VDMA Path.
How to solve this issue?
I have attached timing report and design pdf.
In design pdf
FCLK_CLK0 50MHz
FCLK_CLK1 200MHz
FCLK_CLK2 37.125MHz (output resolution clock for HD@30fps)
kannan
Tags (2)
Hi @kannan,
Could you share the timing repport after synthesis?
Florent
      How to generate timing report after synthesis?
      In Reports column , route timing summary is only visible.
kannan
  I have attached the screen shot of the timing violation after synthesis.
kannan
Hi @kannan,
What happen if you use a slower clock for the AXI4S interface of the VDMA?
Florent
   Before I used two clocks in AXI VDMA . The 200MHz for Read Channel and 37.625MHz(Video Clock HD@30fps) for Write Chennel. But i had big timing violation. So i connected 200MHz to Read and Write Channel.
Kannan
Hi @kannan,
Could you share your project?
Florent
HI @kannan,
Any update on this? Could you share your project?
Florent
i am not able to upload the project. It is 133Mb. But the maximum size of upload size is around 20 Mb.
Kannan
HI @kannan,
I sent you a email last week to upload your project but I didn't receive any files back. Did you get the email?
Do you have any progress?
Florent
Hi @kannan,
If you change the memory map address width in the VDMA it should help meeting timing. Also make sure to use the max burst size.
Florent
HI @kannan,
What is your status on this? Were you able to make progress?
Florent
