pfmiaja
Accel DSP block in System Generator
Hi:
I'mtrying to put an AccelDSP design into a System Generator model. I've done this by exporting it from AccelDSP to the library of System Generator. But whhen I try to simulate it it shows me this error:
'Block requires all inport rates to be the same or constant.  The rates are set to:
Port sample: 1.#INF'
I've set the Simulink period to 1 and the clock period to 20 ns, but I don't know how to set the port rates to a constant. I don't knoq if it has to be done on AccelDSP or in Simulink.
Can you give me some advice?
sandeep.ism
well i am also having a similar problem with the blocks created using AccelDSP
i got error saying:  "error undriven input port "
although all the input port are connected and all input to the xilinx blocks are though xilinx block
wating for words of knowledge....
