m.yaghmai
Audio through HDMI IP cores
I am working on a project that I need to get the video and audio from hdmi rx ss and sends them to hdmi tx ss and then see the video and hear the audio from the screen which is connected to hdmi port. I can get the video with no issue but the audio is not working as expected.
The HDMI RX Subsystem should take the audio and sends parallel audio to I2S transmit IP core and then the I2S transmit send the serialized audio to I2S Receive IP and from I2S receive the parallel audio data goes to HDMI TX Subsystem. The HDMI TX Subsystem should take audio streams and transfers it to an HDMI stream. The stream is then forwarded to the video PHY layer and I should be able to hear the audio from the screen connected to the HDMI port.
I inserted multiple logic analyzer (ILA) cores in the design. I see the parallel data on the output of hdmi rx ss, I see the serialized data in the output of the i2s transmit and I see the parallel data in the input of HDMI tx ss but I do not hear any audio coming out of the screen.
Does anyone used HDMI IP cores for audio before ? Is there an example of the audio that I can use as a reference ? Does anyone have any idea what can be wrong ?
Tags (3)
ashokkum
Hello @m.yaghmai ,
Could You please check our pass through example design with I2S audio developed on ZCU102 board. The same was addressed in the Chapter - 6, example design section of PG236.
Kindly go through the example design and let me know If You have any concerns against to this case.
With Regards,
Ashok.
Tags (2)
m.yaghmai
Hello @ashokkum
Thank you very much for the suggestion. I do not have the ZCU102 development board but I checked the example design in the document you suggested. The issue is in HDMI TX SS when it receives the AXI audio and needs to converts it back to HDMI stream. As I mentioned before, the audio goes all the way to hdmi tx subsystem and I see the parallel data on the hdmi tx subsystem audio input(AUDIO_IN_tdata) but I do not hear any audio coming out of the screen which is connected to it. Is there any specific configuration that needs to be done on hdmi tx ss for audio ?
m.yaghmai
Does anybody have a suggestion for my issue ?
I started playing with audio Infoframe on SDK and now I have some audio through HDMI but with so much noise on it. so for example I hear the music I play but with so much noise on top of the music.
Is there any specific parameter I need to set ? How about video infoframe ?
This is what I have in SDK :
// Send Vendor Specific InfoFrame
void SendVSInfoframe(XV_HdmiTxSs *HdmiTxSsPtr)
	XHdmiC_VSIF *VSIFPtr;
	VSIFPtr = XV_HdmiTxSs_GetVSIF(HdmiTxSsPtr);
	XHdmiC_Aux Aux;
	(void)memset((void *)VSIFPtr, 0, sizeof(XHdmiC_VSIF));
	(void)memset((void *)&Aux, 0, sizeof(XHdmiC_Aux));
	VSIFPtr->Version = 0x1;
	VSIFPtr->IEEE_ID = 0xC03;
	if (XVidC_IsStream3D(&(HdmiTxSsPtr->HdmiTxPtr->Stream.Video))) {
		VSIFPtr->Format = XHDMIC_VSIF_VF_3D;
		VSIFPtr->Info_3D.Stream = HdmiTxSsPtr->HdmiTxPtr->Stream.Video.Info_3D;
		VSIFPtr->Info_3D.MetaData.IsPresent = FALSE;
	} else if (HdmiTxSsPtr->HdmiTxPtr->Stream.Video.VmId ==
					   XVIDC_VM_3840x2160_24_P ||
					   XVIDC_VM_3840x2160_25_P ||
					   XVIDC_VM_3840x2160_30_P ||
					   XVIDC_VM_4096x2160_24_P) {
		VSIFPtr->Format = XHDMIC_VSIF_VF_EXTRES;
		/* Set HDMI VIC */
		switch(HdmiTxSsPtr->HdmiTxPtr->Stream.Video.VmId) {
			case XVIDC_VM_4096x2160_24_P :
				VSIFPtr->HDMI_VIC = 4;
				break;
			case XVIDC_VM_3840x2160_24_P :
				VSIFPtr->HDMI_VIC = 3;
				break;
			case XVIDC_VM_3840x2160_25_P :
				VSIFPtr->HDMI_VIC = 2;
				break;
			case XVIDC_VM_3840x2160_30_P :
				VSIFPtr->HDMI_VIC = 1;
				break;
			default :
				break;
	} else {
		VSIFPtr->Format = XHDMIC_VSIF_VF_NOINFO;
	Aux = XV_HdmiC_VSIF_GeneratePacket(VSIFPtr);
	XV_HdmiTxSs_SendGenericAuxInfoframe(HdmiTxSsPtr, &Aux);
void SendInfoframe(XV_HdmiTxSs *HdmiTxSsPtr)
	u32 Status;
	XHdmiC_AVI_InfoFrame *AviInfoFramePtr;
	XHdmiC_AudioInfoFrame *AudioInfoFramePtr;
	AviInfoFramePtr = XV_HdmiTxSs_GetAviInfoframe(HdmiTxSsPtr);
	AudioInfoFramePtr = XV_HdmiTxSs_GetAudioInfoframe(HdmiTxSsPtr);
	AudioInfoFramePtr->Version            = 1;
	AudioInfoFramePtr->ChannelCount       = 1;
	AudioInfoFramePtr->CodingType         = XHDMIC_AUDIO_CODING_TYPE_PCM;
	AudioInfoFramePtr->SampleSize         = XHDMIC_SAMPLE_SIZE_24;
	AudioInfoFramePtr->SampleFrequency    = XHDMIC_SAMPLING_FREQUENCY_48K;
	AudioInfoFramePtr->CodingTypeExt      = 0;
	AudioInfoFramePtr->ChannelAllocation  = 0;
	AudioInfoFramePtr->LFE_Playback_Level = 0;
	AudioInfoFramePtr->LevelShiftVal      = 0;
	AudioInfoFramePtr->Downmix_Inhibit    = 0;
	AviInfoFramePtr->Version		= 3;
	AviInfoFramePtr->ColorSpace		= XHDMIC_COLORSPACE_RGB;
	AviInfoFramePtr->ActiveFormatDataPresent = 0;
	AviInfoFramePtr->BarInfo		= XHDMIC_BAR_INFO_NA;
	AviInfoFramePtr->ScanInfo		= XHDMIC_SCAN_INFO_NA;
	AviInfoFramePtr->Colorimetry		= XHDMIC_COLORIMETRY_ITU709;
	AviInfoFramePtr->PicAspectRatio		= XHDMIC_PIC_ASPECT_RATIO_NA;
	AviInfoFramePtr->ActiveAspectRatio	= 0	;
	AviInfoFramePtr->Itc			= 0	;
	AviInfoFramePtr->ExtendedColorimetry = XHDMIC_EXTENDED_COLORIMETRY_YCC_601	;
	AviInfoFramePtr->QuantizationRange = XHDMIC_RGB_QUANTIZATION_RANGE_DEFAULT	;
	AviInfoFramePtr->NonUniformPictureScaling = XHDMIC_NON_UNIFORM_PICTURE_SCALING_NA	;
	AviInfoFramePtr->VIC = 16;
	AviInfoFramePtr->YccQuantizationRange = XHDMIC_YCC_QUANTIZATION_RANGE_LIMITED	;
	AviInfoFramePtr->ContentType	= XHDMIC_CONTENT_TYPE_GRAPHICS;
	AviInfoFramePtr->PixelRepetition= XHDMIC_PIXEL_REPETITION_FACTOR_1;
	AviInfoFramePtr->TopBar		= 0	;
	AviInfoFramePtr->BottomBar	= 0	;
	AviInfoFramePtr->LeftBar	= 0	;
	AviInfoFramePtr->RightBar	= 0	;
	Status = (XST_FAILURE);
	if (!IsPassThrough) {
		// Generate Aux from the current TX InfoFrame
		AuxFifo[0] = XV_HdmiC_AVIIF_GeneratePacket(AviInfoFramePtr);
		XV_HdmiTxSs_SendGenericAuxInfoframe(HdmiTxSsPtr, &(AuxFifo[0]));
		int result_SendGenericAuxInfoframe;
	AuxFifo[0] = XV_HdmiC_AudioIF_GeneratePacket(AudioInfoFramePtr);
		SendVSInfoframe(HdmiTxSsPtr);
	} else {
		if(AuxFifoCount > AUXFIFOSIZE) {
			AuxFifoStartIndex = AuxFifoEndIndex;
	// If PassThrough, update TX's InfoFrame Data Structure from AuxFiFO
	while (AuxFifoStartIndex != AuxFifoEndIndex) {
		if(AuxFifo[AuxFifoStartIndex].Header.Byte[0] == AUX_VSIF_TYPE) {
		// Reset Vendor Specific InfoFrame
			XV_HdmiC_VSIF_ParsePacket(&AuxFifo[AuxFifoStartIndex],VSIFPtr);
} else if(AuxFifo[AuxFifoStartIndex].Header.Byte[0] ==
		AUX_AVI_INFOFRAME_TYPE) {
// Reset Avi InfoFrame
(void)memset((void *)AviInfoFramePtr, 0,sizeof(XHdmiC_AVI_InfoFrame));				XV_HdmiC_ParseAVIInfoFrame(&AuxFifo[AuxFifoStartIndex],AviInfoFramePtr);
					AUX_AUDIO_INFOFRAME_TYPE) {
// Reset Audio InfoFrame
(void)memset((void *)AudioInfoFramePtr, 0,sizeof(XHdmiC_AudioInfoFrame));
				XV_HdmiC_ParseAudioInfoFrame(&AuxFifo[AuxFifoStartIndex],AudioInfoFramePtr);
Status = XV_HdmiTxSs_SendGenericAuxInfoframe(HdmiTxSsPtr,&(AuxFifo[AuxFifoStartIndex]));
/* If TX Core's hardware Aux FIFO is full, break from the while
* loop, retry during the next main while iteration.
if (Status != (XST_SUCCESS)) {
	xil_printf(ANSI_COLOR_RED "HW Aux Full" ANSI_COLOR_RESET"\r\n");
			if(AuxFifoStartIndex < (AUXFIFOSIZE - 1)) {
				AuxFifoStartIndex++;
			} else {
				AuxFifoStartIndex = 0;
		AuxFifoCount = 0;
void TxInfoFrameReset(void)
	AviInfoFramePtr = XV_HdmiTxSs_GetAviInfoframe(&HdmiTxSs);
	AudioInfoFramePtr = XV_HdmiTxSs_GetAudioInfoframe(&HdmiTxSs);
	(void)memset((void *)AviInfoFramePtr, 0, sizeof(XHdmiC_AVI_InfoFrame));
	(void)memset((void *)AudioInfoFramePtr, 0, sizeof(XHdmiC_AudioInfoFrame));
	AviInfoFramePtr->Version = 2;
	AviInfoFramePtr->PicAspectRatio = XHDMIC_PIC_ASPECT_RATIO_16_9;
I also attached the hdmi tx subsystem IP configuration.
