gabirmann
Autofocus use sobel filter
Dear all , somewhere i find sobel filter VHDL code and tested it, as shown in attached file.
So i plan to implement  it in my motorized  autofocus  camera , I am not so good coder and math guy, but exactly know that need to count edges and find it by making moving by focusing stepper motor.. But cannot do this :(.
So has someone used sobel filter for making autofocus.? pls help ,
Tags (2)
jmcclusk
Mentor
Mentor
this is a tricky thing to do automatically, because as a camera changes focus, different things in the image will come into focus (foreground and background objects)..    There will be several peaks in the focus "metric" of good focus.
This paper explains some of the ways that focus can be measured:
https://cs.uwaterloo.ca/~vanbeek/Publications/spie2014.pdf
jmcclusk
Mentor
Mentor
florentw
Hi @gabirmann,
The link provided by @jmcclusk looks relevant to your question. Did it helped you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" buton below the reply)
Thanks and Regards,
Florent
