CSI2-TX Word Count
I'm looking for some clarification on the Word Count that is input onto _tuser[63:48] for the CSI2-TX subsystem IP:
    • Is this number of words per line?
    • By word does it actually mean byte?
    • I am planning to use YUV420, 10-bit. So, e.g. for 1920x1080:
      • Odd lines have (1920 * (5/4)) = 2400 Words
      • Even lines have (1920 * 2 * (5/4)) = 4800 Words
      • Is this correct?
Re: CSI2-TX Word Count
Hello Andy  andy.martin@videon-central.com
Yes, your understanding is correct.
> If we use YUV422, 8-bit, 1920x1080:
> Lines have (1920 * 2) = 3840 Words
> Is this correct?
Yes.
>In addition, does the core make decisions based on "Data Type"? It seems I could repackage 10-bit into 8-bit and use the correct Data Type.
Yes, this is also correct.
You could repackage your data and tell MIPI CSII-2 TX that you are sending YUV422-8bit by using DataType=0x1E (or other supported data tyoes).
Please note that YUV420 has a different word per-line for Even and Odd lines. I don't think this is something we have tested before.
You need to test/verify this usecase on your design.
Kind regards
Leo
Hello andy.martin@videon-central.com
As mentioned by MIPI CSI-2 spec,
YUV420 is a secondary data types, which unfortunately not supported by MIPI CSI-2 TX Subsystem.
PG260 mentioned a list of unsupported features:
Please consider to use YUV422 8bit data type instead.
Kind regards
Leo
Leo,
That is unfortunate. However, the questions remain:
  • If we use YUV422, 8-bit, 1920x1080:
    • Lines have (1920 * 2) = 3840 Words
    • Is this correct?
Andy
> Is this correct?
Yes.
Kind regards
Leo
