zhanyan110
Can't enable command mode for MIPI DSI Subsystem IP.
Hi experts,
I use MicroBlaze core to initial MIPI DSI IP. I want to use command mode for initial peripheral OLED screen. After I set bit3 enable to CCR register(0x00), and then read CCR register(0x00) and STATUS register(0x2C), the bit3 of CCR is still zero, and the bit6 and bit7 of STATUS(0x2C) is still zero. what's the possible reason ?
the controller ready bit is high, and the core enable bit is low.
karnanl
Hello @zhanyan110
DCS Long packet is supported from 2019.2.
Please upgrade your Vivado version.
Leo
Versal Blogs
karnanl
Hello @zhanyan110
Did you provide a stable 200MHz clock to dphy_clk_200M pin ?
Did you reset the IP correctly ? (See also PG238 Chapter3)
Did you enable the core ? ( Please see bit[0] below )
Please share your register dump, so I can double check the value for you.
Leo
Versal Blogs
zhanyan110
Hi karnanl,
Do I need set the timing register before I use command mode for long packet command ?
karnanl
Hello @zhanyan110
I believe configuring the timing registers are not necessary for sending long packet command.
Leo
Versal Blogs
zhanyan110
Did you provide a stable 200MHz clock to dphy_clk_200M pin. ---- YES
Did you reset the IP correctly. ---- YES
Here is my C code, and the result, please help me check.
karnanl
Hello @zhanyan110
1. According to Status Register ( Address 0x2C == 0x20 )
   It seems that the MIPI DSI TX is not ready to accept any Long/Short Packet.
2. Please follow the procedure stated in PG238 to enable command mode.
    I believe the Core Configuration Register is "0x04",
    So Core is not enabled, and DSI is in Video mode.
Leo
Versal Blogs
zhanyan110
Hi karnanl,
I modify the C code as below ( picture1 ).
After I enable bit3 and bit0 in CCR register, the CCR value readback is still video mode. and the Status Register is still not ready to accept any Long/Short Packet.
karnanl
Hello @zhanyan110
What is your Vivado version ? Could you please share your XCI ?
Is the "DCS Command Mode" enabled ?
Leo
Versal Blogs
zhanyan110
I have tried vivado2018.3 and 2019.1, both met the same issue.
It seems my IP version is v2.0, there is no option "DCS command mode".
karnanl
Hello @zhanyan110
Leo
Versal Blogs
zhanyan110
After I upgrade to Vitis 2020.1. I can see the option "DCS command mode".
But  a new problem happen. When I run debug the C code with "XDsiTxSs_CfgInitialize(&DsiInstance,DsiConfigPtr,DsiConfigPtr->BaseAddr);"
the program will jump to line 244 in xdphy.c at the beginning. It is very weird.
karnanl
Hello @zhanyan110
Okay that is good to hear.
Why you are using D-PHY driver ? I don't think it is necessary for DSI TX...
Leo
Versal Blogs
zhanyan110
I didn't use D-PHY driver. the core-program seems run fly with XDsiTxSs_CfgInitialize(&DsiInstance,DsiConfigPtr,DsiConfigPtr->BaseAddr);
karnanl
Hello @zhanyan110
Tried to read the DSI driver. It seems in 2020.1 XDsiTxSs_Activate() has been modified.
Now the function also enable/disable sub-cores, when calling XDsiTxSs_Activate().
So, that's is why XDsiTxSs_Activate() , will also activate D-PHY. (XDphy_Activate)
I hope this clarify your question.
Kind regards
Leo
Versal Blogs
zhanyan110
karnanl,
Do the DSI IP have read channel for command mode ?
For example, If I want to read register value from the OLED displayer(peripheral device) to FPGA, how to do it ?
karnanl
Hello @zhanyan110
Unfortunately Xilinx MIPI DSI TX Subsystem does not support any read command.
Kind regards
Leo
Versal Blogs
