[DRC REQP-61] How can I connect 'clk_hs_rxp/rxn' to MIPI DPHY Rx IP?
I’m using the MIPI DPHY Rx IP and got a DRC errors like below.
  • [DRC REQP-61] ibufds_connects_I_active: IBUFDS U_CORE_TOP/U_PHY_FPGA/inst/inst/mipi_dphy_0_rx_support_i/slave_rx.mipi_dphy_0_rx_ioi_i/ibufds_clk_inst pin I has an invalid driver U2_CLK_GEN/inst/mmcm_adv_inst
  • [DRC REQP-62] ibufds_connects_IB_active: IBUFDS U_CORE_TOP/U_PHY_FPGA/inst/inst/mipi_dphy_0_rx_support_i/slave_rx.mipi_dphy_0_rx_ioi_i/ibufds_clk_inst pin IB has an invalid driver U2_CLK_GEN/inst/mmcm_adv_inst
Connection of ‘clk_hs_rxp/clk_hs_rxn’ causes DRC error.
MMCM is used to receive ‘clk_hs_rxp/clk_hs_rxn’ now.
When 'clk_hs_rxp/rxn' are connected to MIPI DPHY Rx IP directly, pin assignment is disappeared.
Using ‘IBUFDS_DIFF_OUT ‘ has a similar error.
Thank you for your help in advance.
JJ
<condition>
- FPGA: Kintex 7
- Vivado: 2018.3
- I_HS_CKP/I_HS_CKN : from MC20901(meticom)
- MMCM
clk_wiz_1 U2_CLK_GEN
    .clkfb_in(clkfb_out),     // input clkfb_in
    // Clock out ports
    .clk_out1(HS_CKP),     // output clk_out1
    .clk_out2(HS_CKN),     // output clk_out2
    .clkfb_out(clkfb_out),    // output clkfb_out
    // Status and control signals
    .resetn(1'b1), // input resetn
    .locked( ),       // output locked
   // Clock in ports
    .clk_in1_p(I_HS_CKP),    // input clk_in1_p
    .clk_in1_n(I_HS_CKN));    // input clk_in1_n
 (HS_CKP: no buffer, HS_CKN: phase 180 degree, no buffer)
I found I_HS_CKP/CKN are not SRCC/MRCC pins. (pg202, page 84)
Is there any way to use MIPI DPHY Rx IP?
Hello @jjlim
Since you are using 7-series device, you need to use SRCC/MRCC pins for D-PHY clock lane. (as mentioned in PG202)
Are you saying that you cannot use SRCC/MRCC pins on your board ??
Kind regards
Leo
Hello Leo.
Yes. clk_hs_rxp/rxn are connected to user I/O in the board.
I'd like to check if I can use D-PHY IP in this situation before PCB revision.
Thank you for your help.
JJ
Hello JJ @jjlim
Unfortunately no, without using SRCC/MRCC pins MIPI D-PHY IP will not be implementable.
For pin-assignment checking, We do suggest users to create a small test design and run implementation with Vivado before making the board.
Kind regards
Leo
Hello Leo
Thank you for your information and advice.
I will follow your guide.
Best regards
JJ
