sdcf2003
Directly connect video-in-axi4-stream with axi4-stream- to-video-out without VDMA
I built a video stream line:adv7611->video-in-axi4-stream->axi4-stream- to-video-out->adv7511 with zedboard+avnet FMC module. I didn't insert a VDMA between Video-In-AXI4-Stream and AXI4-Stream-to-Video-out like reference design.
   I found that the locked signal of AXI4-Stream-to-Video-out always kept low. It means that the AXI4-Stream-to-Video-out didn't locked the input axi4-stream video.
  The video-in-axi4-stream and axi4-stream- to-video-out share same aclk(150M) and reset signal. The output of adv7611 is 1080p60hz yuv4:2:2. The axi4-stream- to-video-out works in slave mode. Video timing controller is 1080p.
Following is the block design diagram.
But if replaced the Video-to AXI4-Stream and ADV7611 with a Test Pattern Generator. I can get a GOOD output of ADV7511 and a high level locked signal.
So I wonder what the differences between a real video and Test Pattern Generator?
There must be something out of sync.  In this case how to configure these IP?
The VDMA is necessary?
I add a system ila between  Video-to AXI4-Stream and AXI4-Stream-to-Video-out.
I got following ila capture image. The EOL(TLAST) and EOF(TUSR)  signals look like good.
Following is the status signal of AXI4-Stream-to-Video-out.
The status is 0x000c008f
watari
Hi @sdcf2003
The differences between them are video format (NV16 vs guess RGB888) and internal video timing.
You must consider to use remapper or to change video format.
It depends on what you want to achieve.
Best regards,
florentw
Hi @sdcf2003
First you might want to read my article on how to debug the AXI4-Stream to video out:
Video Beginner Series 8: Debugging the AXI4-Stream to Video Out IP
But here the issue seems pretty clear. We can see that the AXI4-Stream to video out is always in underflow. So it means that there is not enough data coming in.
The difference with the TPG is that it does not have blanking period so it can feed the data during this periods.
An AXI VDMA can definitely help here. But it should be possible without it.
You might want to read the section Buffer requirements of the PG044. So with that you might see that increasing the hysteresis level of the AXI4-Stream to video out might help.
There are other options to explore (using the VTC as detector + generator to have a fsync) which can help
Florent
florentw
HI @sdcf2003
Any update on this? Were you able to make your project working?
Florent
