markus.hertel
Display Port TX 1080p@60 4 ppc
Hello Together,
I want to use the video phy  with 1080p@60Hz. I have a incomming native video stream with 4 pixels per clock.(At the moment I added a video timing generator with 1080p setup to be sure that the hsync, vsync and enable signals are 100% correct).
If I understand it correctly I need to set the tx_vid_clk_stream1 to 37.125 MHz?
trevorr
Hi @markus.hertel
After testing I can confirm that the frequency you suggested will work for the tx_vid_clk_stream1.
Trevor Rishavy
trevorr
Hi @markus.hertel ,
I am testing to see what the tx_vid_clk_stream1 is set to in my design running 4 lanes at 1080p60, but I believe that frequency is correct. I will let you know what I find on my end.
Trevor Rishavy
markus.hertel
Thank you trevorr
trevorr
Hi @markus.hertel
Trevor Rishavy
