Display port to MIPI CSI converter IP and solution
Hi, there
I want design a Dispaly port to MIPI CSI  converter . I need some suggstion about the chip and the IP needed.
Henry
Hi @henryjsw
Do you want to build the following ?
DP Rx IP -> MIPI CSI Tx
I guess you want to build the following ???
DP Rx IP -> MIPI DSI Tx
Best regards,
I want :
Use vedio card as carmera input.
Henry
@watari wrote:
Hi @henryjsw
- Product Discontinuation Notice for MIPI CSI2 Tx IP (But might be good news)
https://www.xilinx.com/support/documentation/customer_notices/XCN19027.pdf
[Florent] - This is indeed a good news for customer has the MIPI IPs will all be included in vivado for free (i.e. they will not require a license anymore)
Florent
Hi @henryjsw,
Were the responses from Watari and Florentw enough to answer your question?
If so, can you mark one of their solutions as accepted so that the thread is closed?
Thank you,
Sam
Xilinx Video Design Hub
Hello @henryjsw ,
I am attempting to implement something similar. DP to MIPI-DSI. Did you figure out a solution for DP to CSI?
Pascal.
