DisplayPort resolution on ZCU-102
How to change resolution for the DisplayPort interface on the ZCU-102 evaluation board?
I have a 272x340 display. Is it supported by ZCU-102?
HI @efridman,
i don't understand why MIPI core is not part of Zynq chip in the first place being the interface for high quality embedded displays
That was the choice which was made for MPSoC. For most customers, using the PL is not an issue
Florent
Hi @efridman
First of all, does your display (272x340) have Display port ?
I guess your display (272x340) has mipi or paralell interface.
If my understanding is correct, you can not output video signal to your display...
Best regards,
yes. its a MIPI interface and i plan to use dp2mipi adaptor. why do you think it is not possible?
Hi @efridman,
There is a lot of discussion on adapters with the Displayport controller or the DP Subsystems. Most of the adapters are not working.
You would need an active adapter which is fully DP sink compliant. In most case it is not true.
So as @watari, I do not recommend you to go this way
Florent
i have a shelf item targeted for this purpose-Lontium LT7911 chip. how i can be sure if it works?
Hi @efridman,
The only way you can be sure it is working is by testing it.
As mentioned, Xilinx does not supports adapters. The user is responsible for doing the caracterization
Florent
sounds strange to me that xilinx does not provide any technical info what is working and what is not. i would expect a detailed explanation about DP interface so at least one will know how to design compatible adaptor. dp interface is somehow stange choice for embedded devices
Hi @efridman,
The DP controller supports RX devices that are compliant with the DP1.2 spec without optional features. For example, the displayport controller does not support the VESA DisplayPort Interoperability Guidelines (also known as DisplayPort++), which is required to support Passive DisplayPort cables.
Xilinx cannot test all equipment on the market to know if they are working or not... If you think your adapter is fully compliant to the DP1.2 spec then it might work.
Florent
Hi @efridman
I'm sure that the suitable solution is to choose MIPI interface instead of Display Port.
The reasons are as below.
1. Required technology is different between MIPI and DP in this situation.
2. At least you implement DP Tx driver (link training and so on. It's difficult), if you use. However, if you use MIPI, the implementation of FW is easy.
3. Also, it is difficult to find active adapter from DP to MIPI.
4. and so on.
Therefore, I don't suggest to use DP. I only suggest to use MIPI to connect to your device.
Best regards,
the DP interface is the only video interface on the PS side with drivers already implemented.
HI @efridman,
May we know why you need to have the solution in the PS, not in the PL?
Florent
of course. we don’t want to activate PL side just for display. the PL static power consumption is about 1-1.5 which is too high for us
Hi @efridman,
Ok I understand. So as mentioned, you will need to do your own characterization for the adapter. Again, Xilinx is not supporting adapters but this does not means that they will not work.
Note that some might work requiring changes in the drivers.
You might want to discuss this matter with your FAE
Florent
Hi @efridman
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
Hi @efridman
FYI.
https://www.xilinx.com/support/answers/68227.html
However, I don't suggest to use DP Tx to MIPI display...
I think that "The right man for the right job."
In this case, even if it increase power consumption, I suggest to implement MIPI Tx...
Because of a mechanism of DP is little complex...
Best regards,
I'm already convinced that using the DP to drive the MIPI interface could be problematic. With this said, i don't understand why MIPI core is not part of Zynq chip in the first place being the interface for high quality embedded displays.
HI @efridman,
Florent
