Displayport 1.4 and MCDP6000
I'm working on a custom prototype board with DisplayPort, actually I used the DP159 as specified by product guide PG233, now I found a new product guide PG300, it uses the MCDP6000 as a retimer to reach 8K 30Hz.
Actually I can't find a demo board or an reference design/schematic to understand the effort to start using the new retimer in the next revision of our board, where I can find more info?
Hi @auricm,
There should be one FMC card produced by Inrevium but it is not available yet. But we have a reference design ready as per pg300.
My recommendation is to contact your FAE (ask him to contact marketing for this).
Hi @auricm,
can you please tell me, where the mentioned reference design for displayport 1.4 subsystem using the inrevium displayport 1.4 FMC-card is available.
We have an ZCU102-Board as well as the displayport 1.4 FMC card TB-FMCH-VFMC-DP available here.
Thanks and best regards
Michael Tornow
HI @rumburak,
Refer to chapter 6 of PG299 or PG300 for the example design.
Please create a new topic if you have any question (I am closing this topic for new replies as already solved)
