furball
Displayport 1.4 rx only example
HI,
Is Displayport 1.4 rx only example working functionally?
I'm using zcu102+FMC with this example, vivado 2020.1, but when I connect rx port to DP source, there's just an abnormal monitor device shown up, and only in device manager, the XLX0123 device name is been recognized.
kshimizu
Hello @furball ,
Xilinx has evaluated the following equipment.  Could you please tell us in detail what is the issue?
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
watari
Hi @furball
It seems vendor specific name like EDID on DP Tx.
Would you make sure connection ?
Best regards,
furball
Hi @watari , @kshimizu ,
After changing to another dp source, the operation went normal. But I guess it’s related to compatibility, cause I’ve used both source with pass-through example and nothing went wrong. Any suggestion about compatible problems?
furball
The source which has problem with link is Nvidia P3200 , platform windows 10
watari
Hi @furball
It seems driver issue about parsing EDID on DP source device.
Would you update NVidia's driver ?
Also, would you try making sure protocol by ex. DP analyzer on DP AUX channel, if possible ?
Best regards,
furball
OK I’ll check the driver version.
