Does Video Codec Unit present inside Zynq Ultrascale+ series uses OS for H.264/H.265 compression ?
1) I am reviewing vcu present inside Zynq Ultrascale+ series for one of the applications that require H.264/H.265 compression and decompression of HD/3G-SDI video without use of OS. Does encoder/decoder present inside the VCU is using OS  ?
2) It is possible to fully control both encoder and decoder of vcu using PL side without involving any control signals from PS side?
Tags (3)
While it may be possible to operate the VCU without using a processor, it was not designed with that use case in mind.
I found the following after a quick glance at PG252:
"VCU operation requires the application processing unit (APU) to service interrupts to coordinate data transfer. The encoder is controlled by the APU through a task list prepared in advance, and the APU response time is not in the execution critical path."
Here is a link to PG252:
https://www.xilinx.com/support/documentation/ip_documentation/vcu/v1_1/pg252-vcu.pdf
I'm sure the tasks handled by the processor could be handled with a state machine in the PL, but the level of complexity might make it unattractive.  If power is the issue, you might look at using one of the R5 processors instead of an A53.
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
HI @ankitsohni,
Just to clarify @tedbooth which is really good:
Xilinx currently only supports the use of Linux OS for the VCU. I do not think PL direct programing will be ever enabled.
You might want to discuss with your FAE to see if one of our partner has a soft IP which can fit your needs.
Florent
HI @ankitsohni,
Was the reply from @tedbooth enough from you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" buton below the reply)
Thanks and Regards,
Florent
Thanks for clarification.
