08-28-2018
07:21 AM
- last edited on
08-28-2018
07:58 AM
by
florentw
According to the documentation the DP RX 1.2 and DP RX 1.4 expect the use of respectively a TI DP159 Retimer or a MCDP6000 Retimer.
Is the usage of the retimer mandatory or the DP RX Subsystem IP works good even without a retimer?
We should maintain the layout compact and we have quite strict space requirements
08-28-2018 08:08 AM
Hi @andreac_avnet,
The Displayport RX Subsystem IP (1.2 or 1.4) expects the use of a retimer (DP159 for DP1.2 and MCDP6000 retimer).
The IP passes compliance only with the use of the retimers and is supported by Xilinx only with the use of the mentioned retimers.
With that said, I know customer using the DP SS RX IP 1.2 without the retimer in a specific case. This is not a DP compliant solution and this require a modification of the driver (which expects the retimer). Again this is not supported by Xilinx and you are responsible for testing the system without retimer and modifying the driver.
To conclude, I highly recommend you to use the recommended retimers for your solution and this is the only supported solution.
08-28-2018 08:08 AM
Hi @andreac_avnet,
