ERROR Message (SYSTEM Generator)
hi,
I have simulated a model using System Generator and it showing satisfactory results. But when i am generating HDL coder using Simulink HDL coder i am getting a error " ERROR FROM HDLSHARED: dfconvertsl2pir:invaliddatatype."
How can solve this problem. I am using xilinx simulink blocks in my design.
You probalby need to seperate out the HDL coder blocks from the SysGen blocks.
Then generate the HDL Coder block and pull them back into the SysGen design as a blackbox.
Chris
Versal ACAP: AI Engines | Embedded SW Support
