Error Running CSI-Rx Application Example Design
I'm a fresh user trying to get acquainted with FPGA/ZYNQ programming.
In fact, I'm trying to run the application example design as described here (PG232).
So far I've purchased the required hardware and am able to run the tutorial up to point step 12. on page 68.
I'm unable to Open IP Example Design as this option is greyed out, even after generating the outputs as described earlier.
Did anyone experience this before?
How can I continue?
Is this a license issue? I have access to the default licenses available with ZCU102 EvalBoard. I'm not sure if this is included or not.
Thank you in advance.
Best Regards,
Kristof
Solution : You need to wait until it becomes available ... :)
As part of generating the outputs, you simply need to wait until submodule runs are completed,
progress can be followed in "Design Runs" tab. (little turning symbol)
Update: Via IP catalog I checked for license status on MIPI CSI-s Rx Subsystem and it confirms "Status:Bought", so license should not be an issue.
Hi kli@melexis.com,
Patience is the key to everything ;)
Thank you for sharing the solution. Could you kindly mark your last reply as accepted solution to close the topic?
Thanks and Regards,
