Error occurred during "Rate and Type Error Checking".
The ip port has data type Bool.
The ip port must be a signed or unsigned signal.
Means the ip port has data type bool but it should be signed or unsigned.
But my inputs are unsigned & not even a single block has data type bool but still i am getting this error. why?
What is the meaning for the sentence "Rate and Type Error Checking"?
Hemanth
Re: Error occurred during "Rate and Type Error Checking".
The error occurs when you map an input to a port that is different interms of data type and sampling rate.
Please check if the data types are same and also try with 1 sampling rate for all blocks.
Data type may not be only Bool and signed and unsigned but number of bits and precision like binary points also matter.
Check the gateways or module ports that the error is occuring.
Else show your mdl for more inputs
Vanitha
Vanitha
