jlesquer
Gamma LUT how to update the tables
Hi all,
I'm trying to figure out how to load the registers LUT values for each color manually (accessing to the register addresses). I've seen the pg285 but there's not clear explanation about how to do it. Also I've seen this  related topic but unfortunatelly there's not answer to this...
Given the next gamma 1 table:
unsigned char gamma_lut_values[256] = {
		0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19,
		20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37,
		38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55,
		56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73,
		74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91,
		92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107,
		108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121,
		122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135,
		136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149,
		150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163,
		164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177,
		178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191,
		192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205,
		206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219,
		220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233,
		234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247,
		248, 249, 250, 251, 252, 253, 254, 255
And given the next LUT offsets:
GAMMA_RED         0x0800
GAMMA_GREEN	  0x1000
GAMMA_BLUE	  0x1800
I'm loading the values like this (repeating for all colors the same):
0x0800 -> 0x00010000
0x0808 -> 0x00030002
0x0810 -> 0x00050004
But the resulting image is very noise and saturated on high lights...
Does anyone know how to update properly the table values?
jlesquer
Hi @watari , thanks for the answer, already solved the problem, it was an addressing issue. It works like that:
0x0804 -> 0x00030002
0x0808 -> 0x00050004
watari
Professor
Professor
Hi @jlesquer
Would you make sure endian in gamma lut ?
jlesquer
