dtokhi
HDMI FrameBufferExample Design 2018.1 for VU440 device
Hello.
I am going to be prototyping with HAPS80( VU440) which will consist HDMI.  Our first bring up will be HDMI pass through.
I was reading up HDMI Frame Buffer Example which is perfect for what I want to bring up on HAPs.
What is required required to port this onto a HAPS or (VU440 device)?
Can you give a contact I can work with that will assist me in retargeting this design for VU440 device?
David Tokhi
Tags (2)
samk
Hi @dtokhi,
Take a look at this post on how to contact your FAE. They will be able to help you with the specific details of the port.
I am not sure which example design you are referencing, so I will speak to the example design outlined in PG236.
As a quick overview:
1. you will need to build the example design for the VDU118 as a reference, including the example application.
2. Then you can port this hardware to the VU440, paying attention to your constraints.
3. Once your hardware is complete, you can follow the firmware flow and then use the application for the VCU118 example design.
Keep in mind that the VCU118 example design also requires an FMC daughter card.
2018-08-09 14_11_50-Xilinx Documentation Navigator 2017.2 -  http___www.xilinx.com_support_documenta.png
Sam
Xilinx Video Design Hub
samk
Hi @dtokhi,
Sam
florentw
Hi @dtokhi,
Do you have any update on this? Was the reply from @samk enough for you?
If your question is answered or your issue is solved, please mark the response which helped as solution (click on the button "Accept as solution" below the reply)
Best Regards,
Florent
dtokhi
Yes. Sam has been very helpful along the way.
