How to clear ddr residual memory in vdma application
I need to input a low resolution video and output to a higher resolution using VDMA
No resizing is needed. The video input is expected to be placed at the top left corner of the output screen.
I expected that there should be black screen at  the right edges and at the bottom. Instead, the right edges and the bottom screen keep flashing. A video clip is enclosed below.
My question is how to blank the flashing area
HI @dr.elichan
You might want to refer to the example 2 in the following article I wrote:
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Video-Series-26-Examples-of-advanced-uses-of-the-AXI-VDMA-IP/ba-p/947566
HI @dr.elichan
