12-08-2017 04:50 AM - edited 12-08-2017 04:54 AM
Hello guys,
We intend to use Xilinx MIPI IP cores (only receiver subsystem) implemented in Zynq Ultrascale+ MPSoC in order to accept video data from GMSL or FPD Link III deserializers with MIPI CSI-2 output.
I know that Ultrascale+ architectures have enhanced MIPI D-PHY support capabilities i.e. IBUFDS_DPHY input buffers that will allow us to directly connect MIPI CSI-2 data lanes from serializer to FPGA HP I/O bank. There will be no need for any external resistor since we can internally include 100Ohms resistor as an option. Correct?
What about the MIPI CSI-2 clock signals? What kind of I/O standard should we use for the MIPI CSI-2 clock lane?
What data rate per lane can we have with such enhanced MIPI D-PHY capabilities in Ultrascale+ families? Can we have 1.5Gbps per lane?
Thanks in advance for your time and effort.
Sincerely,
Bojan.
12-12-2017 02:40 AM - edited 12-13-2017 06:57 AM
Hi @bojankoce,
> Yes this is correct
> For ZU+, the xdc constraint are automatically generated by the core and you can do the IO planning in the IP configuration GUI.
Edit: All the MIPI pins (clock + data) need to use the D_PHY IO standard on US+
> Yes as per pg232:
Kind Regards,
Florent
Hi @bojankoce,
> Yes this is correct
> Yes as per pg232:
Kind Regards,
Florent
