bihuf
How to output different line rate with MIPI TX-DPHY
I'm developing a DSI design with K7 device. To verify different DSI display, my design needs to support generating DSI stream with different line rate. But the TX-DPHY IP seems only support fixed line rate.
As far as I know, the MIPI DPHY IP cannot support dynamic line rate change, as mentioned in another topic of "MIPI D-PHY CSI-2 receiver change line rate".
What should I do? Is there any alternative solution for this requirement?
Best regards.
Tags (2)
karnanl
Hello @bihuf
1. Yes, your understanding is correct. Unfortunately Xilinx MIPI D-PHY does not support  dynamic line rate change.
2. If you are planning to use Xilinx DSI TX Subsystem , your use-case is not supported.
Leo
Note :
    We do have a customer who use MIPI D-PHY TX  with dynamic line rate change.
    They generated all MIPI D-PHY TX IP with Shared logic in Example Design, and design a custom shared logic.
    It is possible because they are using their own CSI-2 TX controller, and building a custom shared logic by themselves.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
karnanl
Hello @bihuf
Leo
Note :
bihuf
Hi, Leo
    Thanks for your answer. Very helpful for my design.
     To customize the shared logic, I need to confirm the difference between two TX-DPHY IPs with different line rates is only different MMCM configuration. And the successful customer case is much persuadable.
wenyong
