andreac_avnet
IP with DVI Dual Link
Dear all,
I'm searching an IP similar with this one: Bitec - HDMI 2.0b IP Core
Because it doesn't support Xilinx FPGA's.
Here's some data:
Resolution: 1920x1200 each Link (w/ Dual Link: 2560x1600)
8 bit per channel
24 bit RGB
The main feature is DVI DUAL LINK.
Thanks is advance for your help.
Best regards,
Andrea
samk
Hi @andreac_avnet,
I am not familiar with any Xilinx IP that will support DVI Dual Link. (This will require 2 synchronized PHY interfaces)
Here is a link to Xilinx IP as well as third-party alliance partner's IP.
Sam
Xilinx Video Design Hub
samk
Hi @andreac_avnet,
Sam
