msh
Voyager
Voyager
Keeping video clock constant for vphy
I would like to configure the VPHY IP. But every time there is output resolition change then I donot want video clock to change whereas TDS clock could change. Because I am using the video clock for other PL IPs.
scenario:
If at HDMI 2k monitor is connected then video clock remains the same as it was before with 4k monitor connection. To handle the change we will place scaler to scale down the 4k to 2k. This is scenerio where camera and HDMI ouput work on different resolution.
NOTE:
I know how to handel this in baremetal application. I connected an GPIO with AND to rdy clock signal, where I toggle GPIO but not rdy clock i.e. donot configure the clock and keep the video clock the same. May I know if there is way to do so via linux driver ?
case1:
4k input
4k output
video clock : 297 Mhz
TDS clock : 592 MHz
case 2:
4k input
2k output
TDS clock : 148 Mhz
Best regards
Tags (2)
xud
@msh
The HDMI(includes Video PHY) drivers are outside of linux-xlnx drivers.
Please refer to HDMI driver page on how to add HDMI driver to kernel :
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842136/Xilinx+DRM+KMS+HDMI-Tx+Driver
Followings are the Video PHY drivers :
https://github.com/Xilinx/hdmi-modules/tree/master/hdmi/phy-xilinx-vphy
If you have a closer look, you will find the low level behavior is same as bare-metal drivers. It detects refclk_ready. If you use GPIO to control it, you need to toggle this signal when you do hotplug, change color information. Video PHY will know there is a reference clock change.
xud
@msh
In linux, you can use GPIO too, then generate hdf(or xsa) to rebuild the project. following is the way to enable GPIO. Do you see any issues?
Kernel Configuration Options for Driver
To enable GPIO in the kernel, the following configuration options need to be enabled:
CONFIG_GPIO_SYSFS=y
CONFIG_SYSFS=y
CONFIG_GPIO_XILINX=y (for axi_gpio)
xud
@msh
Devicetree example for GPIO :
axi_gpio_0: gpio@40000000 {
        #gpio-cells = <2>;
        compatible = "xlnx,xps-gpio-1.00.a";
        gpio-controller ;
        interrupt-parent = <&microblaze_0_intc>;
        interrupts = < 6 2 >;
        reg = < 0x40000000 0x10000 >;
        xlnx,all-inputs = <0x0>;
        xlnx,all-inputs-2 = <0x0>;
        xlnx,dout-default = <0x0>;
        xlnx,dout-default-2 = <0x0>;
        xlnx,gpio-width = <0x2>;
        xlnx,gpio2-width = <0x2>;
        xlnx,interrupt-present = <0x1>;
        xlnx,is-dual = <0x1>;
        xlnx,tri-default = <0xffffffff>;
        xlnx,tri-default-2 = <0xffffffff>;
msh
Voyager
Voyager
Isnt the DKM driver i.e vphy, hdmi etc. reconfigure the reference clock every time there is hdmi hot plug ?
also vphy couldnot start after hdmi hot plug detection until it see the ref clock rdy toggle.
In baremetal I donto reconfigure the reference clock, only toggel the gpio. But how will I do it in linux with KMS driver ?
xud
@msh
samk
Hi @msh,
Was Xu able to answer your question?
If your question is answered or your issue is solved, please kindly mark the response which helped find a solution (click on "Accept as solution" button below the reply)
If this is not solved/answered, please reply to the thread giving more information on your current status.
Thanks and Regards,
Xilinx Video Design Hub
