MIPI CSI-2 RX IP requirements for working in a Zynq 7030
We have a design using a sensor from OMnivision Ov2718 (FHD 1920x1080, MIPI-CSI2) TX source and the IP from Xilinx as the RX.
From the sensor the MIPI interface is connected to an external connector and then through a cable to the FPGA board.Capture4.PNG
These MIPI lines are connected to the FPGA in the HS lines with the LVDS_25 Iostandard (picture below).  We are not using the Meticom IC, neither the resistor divider approach to get the Lp lines. Under these conditions what are our chances to make it work with our current Hardware?. Can we expect the MIPI lanes to get up?.  Thanks for your input.
Tags (2)
Hello @jnievesr
Unfortunately, It will not work !
MIPI CSI-2 will not work with only HS lanes connected. You will have to find another solution.
Please fix your board or please buy another board.
Just FYI our MIPI team also tested our MIPI CSI-2 RX IP using Zybo Z7 resistive circuit without any issue.
Zybo Z7 has resistor-network exactly the same configuration as mentioned in XAPP894.
The FPGA device is also similar.
https://reference.digilentinc.com/reference/programmable-logic/zybo-z7/start
https://reference.digilentinc.com/_media/reference/programmable-logic/zybo-z7/zybo_z7_sch-public.pdf
https://reference.digilentinc.com/reference/programmable-logic/zybo-z7/reference-manual
Thanks & regards
Leo
Hello @jnievesr
Thanks & regards
Leo
